[mapguide-trac] #1550: MG Service can't be started while repositories is corrupt
MapGuide Open Source trac_mapguide at osgeo.org
Sat Dec 4 02:12:58 EST 2010
   Reporter:  carlshe  |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Server   |     Version:  2.1.0
   Severity:  trivial  |    Keywords:  service repository
External_id:           |
 Accidentally, MG2.1 can't be started.
 The information from Windows VISTA event viewer is:
 [[BR]]
 An exception occurred in DB component
 DbEnv::dbremove: No such file or directory
 and the information from the Error.log of MG Server is:
 <2010-12-02T22:46:15> 4584 Administrator
  Error: An exception occurred in DB component.
  StackTrace:
   - MgServer.open() line 1083 file
 c:\osgeo\mapguide_21\mgdev\server\src\core\Server.cpp
   - MgServiceManager.Initialize() line 145 file
 c:\osgeo\mapguide_21\mgdev\server\src\common\manager\ServiceManager.cpp
   - MgServerResourceService.OpenRepositories() line 173 file
 c:\osgeo\mapguide_21\mgdev\server\src\services\resource\ServerResourceService.cpp
   - MgRepositoryManager.CleanRepository() line 330 file
 c:\osgeo\mapguide_21\mgdev\server\src\services\resource\RepositoryManager.cpp
  Success: Server stopped.
 <2010-12-02T22:59:51> 5508 Administrator
  StackTrace:
 <2010-12-02T23:04:16> 612 Administrator
  StackTrace:
 <2010-12-02T23:04:48> 1084 Administrator
  StackTrace:
 <2010-12-02T23:06:55> 1504 Administrator
  StackTrace:
 It seems that the repository is corrupt.
 I Renamed the Server/Repositories and restart MGServer again. MG Server
 recreate a new folder 'Server/Repositories' and then MG server runs well
 again.
 It is a pity that the issue can't be reproduced now. Even if I renamed
 some files' names inside repositories or deleted some external spatial
 data files, Now MG can repair repositories automatically while restarted.
 I think Mapguide shouldn't terminate itself while meeting with some non-
 key problems, such as corrupted repository. The repair of the repository
 could be finished by administrator through some tools like Maestro. If
 MGServer is terminated, user will have no visible entries to interact with
 it.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1550>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
