[mapguide-trac] #1552: DB_BUSY errors generated under load
MapGuide Open Source trac_mapguide at osgeo.org
Mon Dec 6 13:47:12 EST 2010
   Reporter:  brucedechant  |       Owner:  brucedechant
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:  2.3
  Component:  Server        |     Version:  2.2.0
   Severity:  major         |    Keywords:
External_id:                |
Changes (by brucedechant):
  * owner:  => brucedechant
Old description:
> The server can generate DB_BUSY errors under load because the session
> repository used by the server to hold all of the client session
> information encounters too much database contention when multiple clients
> need their session information updated.
> The DBXML database used for the session repository does not perform well
> under this condition and ends up locking out other threads from updating
> session information while the updates are done for the thread that has
> the database lock.  The locking of the database is required in order to
> perform write operations and this can take longer than the server’s retry
> mechanism allows resulting in DB_BUSY errors being generated for the
> waiting threads.
> The solution to address this issue is to remove the bottleneck of all
> session information being funneled through a single session repository.
> By having a session repository per created session the bottleneck is
> removed with the only side effect being an increase in the memory used by
> the server.
> To allow for better control over the number of created session
> repositories a new serverconfi.ini property “SessionRepositoriesLimit”
> should be added to restrict this as needed.
New description:
 session information while the updates are done for the thread that has the
 waiting threads.
 session information being funneled through a single session repository. By
 having a session repository per created session the bottleneck is removed
 with the only side effect being an increase in the memory used by the
 server.
 repositories a new serverconfi.ini property “!SessionRepositoriesLimit”
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1552#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
