[mapguide-trac] #1555: Oracle SRID's are soemtimes returned as negative numbers.
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 7 19:12:58 EST 2010
 Reporter:  NormOlsen    |         Owner:  NormOlsen
     Type:  defect       |        Status:  closed
 Priority:  low          |     Milestone:  2.2
Component:  General      |       Version:  2.1.0
 Severity:  minor        |    Resolution:  fixed
 Keywords:  SRID Oracle  |   External_id:  1364216
Changes (by NormOlsen):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Corrected at revision 5446.  Altered the code such that the signed short
 in the CS-MAP dictionary structure is treated as an unsigned short.  Tries
 to do this without using a cast such that it will work on any compiler.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1555#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
