[mapguide-trac] #1577: CCoordinateSystemMathComparator::SameCoordinateSystem() incorrectly returns [false] for equal "arbitrary coordinate systems"
MapGuide Open Source trac_mapguide at osgeo.org
Fri Dec 17 11:57:17 EST 2010
   Reporter:  baertelchen  |       Owner:  baertelchen
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:  2.3
  Component:  General      |     Version:  2.1.0
   Severity:  minor        |    Keywords:  Coordinate System API comparing coordinate systems CCoordinateSystemMathComparator SameCoordinateSystem
External_id:               |
 The CCoordinateSystemMathComparator::SameCoordinateSystem() API allows to
 compare 2 coordinate systems on (mathematical) equality.
 It incorrectly returns [false], however, if the 2 systems to be compared
 are so called "arbitrary system" which do neither reference a datum nor an
 ellipsoid.
 Currently, if none of the 2 is found, the method mentioned above simply
 returns [false], what is not correct for systems like XY-M (Cartesian XY
 meter).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1577>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
