[mapguide-trac] #1260: MText stack code draws invalid line
MapGuide Open Source trac_mapguide at osgeo.org
Mon Feb 1 15:39:47 EST 2010
   Reporter:  waltweltonlair     |       Owner:  waltweltonlair
       Type:  defect             |      Status:  new
   Priority:  low                |   Milestone:  2.3
  Component:  Rendering Service  |     Version:  2.2.0
   Severity:  trivial            |    Keywords:
External_id:                     |
 The MText stack code \S can be used to draw a fraction.  I found some bugs
 with the implementation:
  * In the case where the numerator is wider than the denominator the code
 is drawing the denominator underlined.
  * Underline and overline settings that are enabled before the stack code
 are not handled properly: text within the stack as well as text following
 the stack is not correctly underlined / overlined.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1260>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
