[mapguide-trac] #1260: MText stack code draws invalid line
MapGuide Open Source trac_mapguide at osgeo.org
Mon Feb 1 15:49:15 EST 2010
 Reporter:  waltweltonlair     |         Owner:  waltweltonlair
     Type:  defect             |        Status:  assigned
 Priority:  low                |     Milestone:  2.3
Component:  Rendering Service  |       Version:  2.2.0
 Severity:  minor              |    Resolution:
 Keywords:                     |   External_id:
Comment (by waltweltonlair):
 Attached an image showing the incorrect behavior.  The top row has
 overline enabled for the whole string, while the bottom row has underline
 enabled.  The left column has the numerator narrower than the denominator,
 while the right column has the numerator wider than the denominator.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1260#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
