[mapguide-trac] #907: WFS DESCRIBESCHEMA returns fdo:int32 for integer values
MapGuide Open Source trac_mapguide at osgeo.org
Wed Feb 3 04:29:22 EST 2010
 Reporter:  ksgeograf      |         Owner:
     Type:  defect         |        Status:  new
 Priority:  low            |     Milestone:
Component:  WFS Interface  |       Version:  2.1.0
 Severity:  trivial        |    Resolution:
 Keywords:                 |   External_id:
Comment (by ksgeograf):
 A related issue is that issuing DescribeSchema without a Typename gives an
 xml document with xs:import. However, the xs:import elements are missing
 the namespace attribute, which I belive is mandatory, and in any case
 breaks ArcGIS support.[[BR]]
 Arc also needs the gml namespace imported explicitly:[[BR]]
 <xs:import namespace="http://www.opengis.net/gml" schemaLocation="wfs-
 xsd/feature.xsd />[[BR]]
 And finally, Arc is very happy if you also change
 "gml:AbstractGeometryType" to "gml:GeometryAssociationType".
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/907#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
