[mapguide-trac] #1263: wrong scale values with tiles maps
MapGuide Open Source trac_mapguide at osgeo.org
Fri Feb 5 18:28:44 EST 2010
   Reporter:  rflorez      |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.1.0
   Severity:  major        |    Keywords:
External_id:               |
 When using static layers (tiles maps), the ajax viewer (in mapframe.aspx
 file) generates a list of scales with a string using "," instead of "." as
 decimal separator. Javascript not properly recognize the value of the
 scales and do not use the decimal part.
 This is a problem when have static and dynamics layers together because
 the
 dynamic layer is generated with different scale
 http://n2.nabble.com/file/n4521707/error.png
 this is the code:
 scales.Sort();
 for(int i = 0; i < scales.Count; i++)
    scaleCreationCode = scaleCreationCode + "scales[" + i + "]=" +
 scales[i] + "; ";
 //I add this line
 scaleCreationCode = scaleCreationCode.Replace(",", ".");
 http://n2.nabble.com/file/n4521707/scale_ok.jpg
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1263>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
