[mapguide-trac] #1266: Fix errors in OgcWmsService.config.awd file
MapGuide Open Source trac_mapguide at osgeo.org
Tue Feb 9 12:46:39 EST 2010
 Reporter:  brucedechant   |         Owner:
     Type:  defect         |        Status:  new
 Priority:  low            |     Milestone:  2.2
Component:  WMS Interface  |       Version:  2.1.0
 Severity:  trivial        |    Resolution:
 Keywords:                 |   External_id:
Old description:
> The OgcWmsService.config.awd file has the following errors in it:
> 1) Comment tag on line 235 needs to be removed due to closing tag being
> on line 237.
> 2) The coordinate system WKT on line 238 is incorrect
New description:
 The !OgcWmsService.config.awd file has the following errors in it:
 1) Comment tag on line 235 needs to be removed due to closing tag being on
 line 237.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1266#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
