[mapguide-trac] #1278: Apache crashes under load
MapGuide Open Source trac_mapguide at osgeo.org
Mon Feb 22 00:13:16 EST 2010
   Reporter:  hubu     |       Owner:  hubu
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:  2.2
  Component:  Web API  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:  Apache upgrading
External_id:  1302967  |
 While running the Grinder test scripts against an Apache/PHP web tier
 configuration the Apache server can crash randomly. This has been observed
 several times while testing.
 The current release of Apache included with MGE2011 is 2.2.11 which has a
 known issue PR 47672.
 Apache PR 47672: fix seg fault under load due to pool concurrency problem
 This Apache defect has been corrected in release 2.2.14.
 We need to upgrade to release 2.2.14.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1278>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
