[mapguide-trac] #1221: Maestro: layer order enhancements
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 4 17:01:50 EST 2010
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  assigned
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  new => assigned
Comment:
 1) It is not possible to do right now in the "Layers by group" list,
 because multi-select in a treeview is not directly supported by .Net.
 I have no problems moving multiple layers in the "Layers by draw order".
 2) That requires that it is possible to somehow highlight the position
 between two elements. This is not directly supported in .Net, and would
 require a custom list/treeview.
 3) No matter how I try to insert/move a layer, it always gets inserted at
 the bottom of the group.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1221#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
