[mapguide-trac] #1228: Maestro: Theming on string columns containing nulls says "no non-null values" even when some exist
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jan 5 18:44:17 EST 2010
   Reporter:  jbirch   |       Owner:  ksgeograf
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:  2.2.0
   Severity:  trivial  |    Keywords:
External_id:           |
 See attached file; attempting to theme (or get values in expression
 editor) for LUMINAIRETYPE results in only NULLs. Works in FDO Toolbox.
 Understand that this may be limitation of API, but wonder if there may be
 a logic gap in the handling of null exceptions or maybe a regression since
 this has worked previously for other files.
 Build 4475
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1228>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
