[mapguide-trac] #1229: Maestro: When theming, option to set border to "darker" version of auto-chosen colour instead of black
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jan 5 19:14:24 EST 2010
   Reporter:  jbirch       |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 It would be visually appealing in many cases to be able to have the border
 colour of a polygon or symbol set to a darker shade of the chosen colour
 rather than black.  This may require some colour model math to apply
 consistently, and you'd run into cases where the result is near-black or
 black anyway.
 If you do implement this functionality, it would be great if you could add
 a "Adjust to fill colour offset" button to the symbol/poly UIs so that it
 can also be applied manually on a per-style basis.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1229>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
