[mapguide-trac] #1231: Maestro: consider adding way to copy/paste resource between windows (using clipboard?)
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jan 6 13:42:54 EST 2010
clipboard?)
   Reporter:  jbirch       |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 It would be incredible useful if chunks of the repository (folders and
 sub-resources, resources, etc) could be copied and pasted using the
 Windows clipboard when working between two Maestro windows connected to
 different servers.  I'm not sure if this is technically feasible, but
 there appears to be some guidance on the subject?
 http://www.codeproject.com/KB/cs/copycustomclasstoclipbrd.aspx
 If this is possible, adding options to "Copy to clipboard" / "Paste from
 clipboard" might be best approach?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1231>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
