[mapguide-trac] #84: Mapping space line widths can cause extreme memory usage
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jan 8 00:01:55 EST 2010
 Reporter:  chrisclaydon       |         Owner:  chrisclaydon
     Type:  defect             |        Status:  closed
 Priority:  high               |     Milestone:
Component:  Rendering Service  |       Version:  1.2.0
 Severity:  critical           |    Resolution:  fixed
 Keywords:                     |   External_id:  927942
Changes (by waltweltonlair):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Actualy borders of area were also fixed.  In GDRenderer polylines and
 polygon borders are both drawn using the same code - !WritePolylines.
 The case that wasn't fixed was enhanced stylization - !DrawScreenPolyline.
 I added the code to limit the line weight.
 All GDRenderer code that allocates brushes now uses good sizes.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/84#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
