[mapguide-trac] #1235: Maestro: Package modification utility adds "DeleteResource" operations for everything when saving
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jan 10 07:53:20 EST 2010
 Reporter:  jbirch   |         Owner:  ksgeograf
     Type:  defect   |        Status:  closed
 Priority:  low      |     Milestone:  Maestro-2.0
Component:  Maestro  |       Version:
 Severity:  minor    |    Resolution:  fixed
 Keywords:           |   External_id:
Changes (by ksgeograf):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Fixed with r4514.
 The default should probably have been to NOT insert the delete.
 I have added a checkbox to the modify dialog so the user can choose if
 delete operations should be inserted.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1235#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
