[mapguide-trac] #1194: Fusion: Fail to narrow Task pane when drag the Vertical Line
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jan 12 22:16:48 EST 2010
 Reporter:  madair            |         Owner:
     Type:  defect            |        Status:  reopened
 Priority:  high              |     Milestone:  2.2
Component:  Fusion Templates  |       Version:  2.0.2
 Severity:  trivial           |    Resolution:
 Keywords:                    |   External_id:  1254170
Changes (by liuar):
  * priority:  low => high
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Hi Mike,
 [[BR]]
 This fix caused severe problem in FF/Safari/Chrome.[[BR]]
 The buttons can not be clicked on the taskpane becausethe ZIndex was set
 to -1. So all the widget in the taskpane can not work now. [[BR]]
 Would you please check it again? Thanks a lot.[[BR]]
 [[BR]]
 Regards,[[BR]]
 Arthur
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1194#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
