[mapguide-trac] #1250: Remove some unneeded asserts from GeometryAdapter
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 25 20:23:39 EST 2010
   Reporter:  waltweltonlair  |       Owner:  waltweltonlair
       Type:  defect          |      Status:  new
   Priority:  low             |   Milestone:  2.3
  Component:  General         |     Version:  2.2.0
   Severity:  trivial         |    Keywords:
External_id:                  |
 There are some asserts in !GeometryAdapter which are exercised when an
 exception is encountered while evaluating an expression.  This can happen,
 for example, when using an expression that refers to an unknown column in
 the feature source.  The asserts end up being very annoying, since they
 will display for each feature that has an invalid expression.
 The exception in this case is normal behavior, and the asserts are not
 needed.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1250>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
