[mapguide-trac] #900: Connections in CLOSE_WAIT status never close and are not reused
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jan 29 15:46:05 EST 2010
 Reporter:  amitmarty  |         Owner:
     Type:  defect     |        Status:  reopened
 Priority:  high       |     Milestone:
Component:  Server     |       Version:  2.0.2
 Severity:  critical   |    Resolution:
 Keywords:             |   External_id:
Comment (by trevorwekel):
 I agree with Bruce. The limit of 62 concurrent connections for the
 ACE_WFMO_Reactor will be too small to fully load upcoming multi-core CPUs.
 The select reactor limit is somwhere near 1000 connections.  I believe a
 3:1 ratio of connections to cores may be required to adequately load the
 !MapGuide Server under certain conditions.
 AMD is scheduled to release 24 cores on a 2 socket machine sometime in Q1
 2010 and Intel also has larger core counts in the works.  Assuming a 3:1
 ratio, 72 connections will be required to load a 24 core machine.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/900#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
