[mapguide-trac] #708: Exceptions thrown on SELECTFEATURES instead of being handled gracefully.
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 10 18:56:02 EDT 2010
 Reporter:  jng        |         Owner:  brucedechant
     Type:  defect     |        Status:  closed
 Priority:  high       |     Milestone:  2.2
Component:  Map Agent  |       Version:  2.1.0
 Severity:  critical   |    Resolution:  fixed
 Keywords:             |   External_id:
Changes (by brucedechant):
  * status:  assigned => closed
  * resolution:  => fixed
  * milestone:  => 2.2
Comment:
 I had to fix the patch before integrating it as it did not compile. It was
 using string and STRING with the + operator which does not work. I also
 had to replace the tabs with spaces.
 Fixed. Trunk r4939
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/708#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
