[mapguide-trac] #1388: MgMap.Create causes crash of 64 bit Web Extensions on Windows
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 28 09:14:41 EDT 2010
   Reporter:  trevorwekel  |       Owner:  trevorwekel
       Type:  defect       |      Status:  new
   Priority:  high         |   Milestone:  2.2
  Component:  Web API      |     Version:  2.2.0
   Severity:  blocker      |    Keywords:  web extensions 64 bit crash
External_id:               |
 On a pre-release build of 64 bit !MapGuide on Windows, maps do not display
 even though the mapagent and web extensions can process requests.  The
 same issue occurs under .Net and PHP.  After some debugging, it was found
 that MgMap.Create causes a fatal application error.  See attached
 test.php.  The following message is generated from the script:
 Hello World
 Session is7fdbd3ee-82b5-11df-8000-000c2939c959_en_7F0000010AFC0AFB0AFA
 SiteConnection is open Resource id ok
 New Mgmap ok Problem:
 The application encountered a problem and could not finish the operation
 you just requested properly.
 Solution:
 If it\'s the first time you met this problem, try again or restart the
 application / session; otherwise, describe the steps to reproduce this
 problem to the server administrator for suggestions.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1388>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
