[mapguide-trac] #1281: Path corrections and small template extensions in mapviewerphp/layerdefinitionfactory.php
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 1 04:55:15 EST 2010
   Reporter:  gabrimonfa   |       Owner:
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  General      |     Version:  2.1.0
   Severity:  trivial      |    Keywords:
External_id:               |
 All path in mapviewerphp/layerdefinitionfactory.php pointing to
 ../../viewerfiles should be corrected to ../viewerfiles
 CreateAreaRule can be extended to accept two more parameters,
 $strokeThickness and $strokeColor.
 CreateLineRule can be extended to accept one more parameter,
 $strokeThickness
 This two last modifications require to modify accordingly also the
 areaRule e lineRule templates in viewerfiles.
 All attached unified diff files refer to <file>_20100226.php (the original
 one) and <file>.php (the modified one)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1281>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
