[mapguide-trac] #1106: MgCoordinateSystem::MathComparator is flying under false colors.
MapGuide Open Source trac_mapguide at osgeo.org
Tue Mar 2 15:47:06 EST 2010
 Reporter:  NormOlsen  |         Owner:  NormOlsen
     Type:  defect     |        Status:  closed
 Priority:  medium     |     Milestone:
Component:  General    |       Version:  2.0.2
 Severity:  minor      |    Resolution:  fixed
 Keywords:             |   External_id:  1255503
Changes (by NormOlsen):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 The MathComparator object was updated so that "mathematical" comparisons
 of ellipsoids and datums was added to the coordinate system comparison.
 Previously, the coordinate system comparator would only compare datum and
 ellipsoid names.  Also added the ability to use different tolerances for
 different projection parameters.  That is, use a different tolerance for
 different parameters types.
 This submission produced revision 4262.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1106#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
