[mapguide-trac] #1286: Modify svn:externals declaration to allow caching of external references
MapGuide Open Source trac_mapguide at osgeo.org
Tue Mar 2 19:29:34 EST 2010
   Reporter:  trevorwekel   |       Owner:  trevorwekel
       Type:  task          |      Status:  new
   Priority:  low           |   Milestone:  2.2
  Component:  Build System  |     Version:  2.2.0
   Severity:  minor         |    Keywords:
External_id:                |
 Currently the svn:externals declarations in Oem are defined as
 CsMap http://svn.osgeo.org/metacrs/csmap/trunk/CsMapDev
 fusion http://svn.osgeo.org/fusion/trunk
 This prevents any external repositories from caching CsMap and fusion.
 Modifying the definitions to use relative paths should allow externals
 repositories to cache both.
 /metacrs/csmap/trunk/CsMapDev CsMap
 /fusion/trunk fusion
 This is needed to reduce the load of svn.osgeo.org when performing regular
 MapGuide builds.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1286>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
