[mapguide-trac] #1287: Add an “Open Task pane” Button for MGE Basic Web Layout
MapGuide Open Source trac_mapguide at osgeo.org
Wed Mar 3 03:19:20 EST 2010
   Reporter:  liuar        |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.1.0
   Severity:  trivial      |    Keywords:
External_id:               |
 Bruno made an enhancement for MapGuide Basic Layout to add a “Close Task
 pane” button which can close the Task Pane to save the workspace (Ticket
 #1044).[[BR]]
 [[BR]]
 [[BR]]
 The problem is, there is not a “Open Task pane” button which could bring
 the Task Pane back when it’s closed. The original idea (Ticket #1044) was,
 once a MapGuide built-in command is executed, e.g. Measure, the
 ExecuteCommand function will expand the TaskPane automatically, this way
 we don’t need an “Open Task pane” button. But for the “non-builtin”
 functions, the TaskPane will not open automatically which will confuse the
 customer.[[BR]]
 [[BR]]
 A solution is, : we add a “Open Task pane” button to make it possible to
 open the Task Pane again at any time. [[BR]]
 When the “Close Task pane” button is clicked, the TaskPane will disappear
 and the “Open Task pane” button will show up like below:
 [[BR]]
 The style of the “Open Task pane” button will change when a mouse hover
 happens, just like the “Close Task pane” button. And there will also be a
 tooltip: “Open the task pane”.[[BR]]
 [[BR]]
 Once the Task Pane has been opened by clicking the “Open Task pane”
 button, the button will hide. [[BR]]
 [[BR]]
 We will also change the “Close task bar” tooltip to “Close Task pane”.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1287>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
