[mapguide-trac] #1302: Modify Linux builds to support per-release install directories and per-release shared libs
MapGuide Open Source trac_mapguide at osgeo.org
Tue Mar 30 15:43:36 EDT 2010
release shared libs
   Reporter:  trevorwekel   |       Owner:  trevorwekel
       Type:  enhancement   |      Status:  new
   Priority:  medium        |   Milestone:  2.2
  Component:  Build System  |     Version:  2.1.0
   Severity:  major         |    Keywords:  linux build
External_id:                |
 Currently, we always build/install !MapGuide to
 /usr/local/mapguideopensource on Linux with .so.7.0.0 as shared library
 names.  To support side by side installation and provide better
 transparency into the actual build of !MapGuide, the installation
 directory will be changed to /usr/local/mapguideopensource-2.2.0 and the
 shared libraries will end in -2.2.0.so.
 As future work, the 64 bit Linux build may be installed to
 /usr/local/mapguideopensource-2.2.0-x64.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1302>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
