[mapguide-trac] #1348: Main window refactoring
MapGuide Open Source trac_mapguide at osgeo.org
Tue May 4 20:51:50 EDT 2010
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  Maestro-2.5
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 The current main window is very "thick" in that it has a lot of
 presentation logic mixed in with the user interface code. This
 presentation logic should be moved out into a separate class. This allows
 for a "thin" main window UI, but more importantly it paves the way for
 modfiying the main window UI to be more modular and extensible (as per the
 Maestro 2.5 roadmap).
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1348>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
