[mapguide-trac] #708: Exceptions thrown on SELECTFEATURES instead of being handled gracefully.
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 5 14:07:23 EDT 2010
 Reporter:  jng        |         Owner:  brucedechant, stevedang
     Type:  defect     |        Status:  new
 Priority:  high       |     Milestone:
Component:  Map Agent  |       Version:  2.1.0
 Severity:  critical   |    Resolution:
 Keywords:             |   External_id:
Comment (by tomfukushima):
 Adding info from Jackie's posting to mapguide internals:
 I've put up a 2nd version of the patch for review as another attachment
 for Ticket 708
 This one omits the <Value> elements if the property value is null
 This also patches the BatchPropertyCollection xsd on the assumption that
 SELECTFEATURES (which is currently broken) is the sole provider of XML in
 this given schema.
 ...and from the above I would add...
 Reviewers: please ensure that BatchPropertyCollection.xsd is the only
 schema that needs to be modified.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/708#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
