[mapguide-trac] #1351: CreateSession can generate invalid session ids
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 7 07:55:32 EDT 2010
   Reporter:  jng        |       Owner:
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:
  Component:  Map Agent  |     Version:  2.2.0
   Severity:  trivial    |    Keywords:
External_id:             |
 The recent security patches for the AJAX viewer imposed the following
 pattern restriction on MapGuide session ids:
 00000000-0000-0000-0000-000000000000_aa_00000000000000000000
 The "aa" component is the locale when the CREATESESSION mapagent call is
 made. However if a custom LOCALE parameter is passed which is not 2
 characters (eg. en-US), then that is actually incorporated into the
 generated session id itself, making it unusable when it is passed to the
 AJAX viewer.
 Attached is a modified mapagent form for the CREATESESSION operation.
 Steps to reproduce:
 1. Load the modified form
 2. Specify a LOCALE greater than 2 characters (eg. en-US)
 3. Invoke the CREATESESSION operation
 4. Open any WebLayout using this generated session id
 5. You will get a http authentication prompt because the generated id
 fails the pattern check.
 The LOCALE parameter should either be rejected or validated to ensure it
 is 2 characters wide.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1351>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
