[mapguide-trac] #1360: Impossible to change the Maestro language.
MapGuide Open Source trac_mapguide at osgeo.org
Sun May 16 20:44:45 EDT 2010
   Reporter:  pcardinal  |       Owner:  jng
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:
  Component:  Maestro    |     Version:  2.1.0
   Severity:  major      |    Keywords:  language login form
External_id:             |
 Version 2.1.0.4814
 Since the new login form to support local connections (not 100% positive
 about the beginning of the present defect), it is impossible to change the
 Maestro language. Maestro is now always using the language  of the OS
 (mine is French), before it was possible to change the language. The steps
 to change the language was to select the language in the login form and
 restart Maestro with the previously selected language.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1360>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
