[mapguide-trac] #1515: Mapguide 2.2RC missing PATH entry causes font problem
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 2 12:57:40 EDT 2010
   Reporter:  gabrimonfa  |       Owner:
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  General     |     Version:  2.2.0
   Severity:  trivial     |    Keywords:
External_id:              |
 Mapguide 2.2RC on centos5
 On Mapguide 2.1 and 2.2beta dropping a font in server/bin (apart from the
 unusual place...) allows its use in layer stylization.
 On Mapguide 2.2RC default (and very ugly) font is used instead of
 specified one, as if the font was missing or not found.
 This can be solved exporting PATH env variable in mgserver.sh and
 mgserverd.sh, with the following command
 export PATH=/usr/local/mapguideopensource-2.2.0/server/bin:$PATH
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1515>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
