[mapguide-trac] #1456: RFC 94 Submission breaks Java API Build
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 8 12:50:40 EST 2010
 Reporter:  NormOlsen     |         Owner:  NormOlsen
     Type:  defect        |        Status:  closed
 Priority:  medium        |     Milestone:  2.2
Component:  Build System  |       Version:  2.1.0
 Severity:  major         |    Resolution:  fixed
 Keywords:  Build         |   External_id:
Changes (by NormOlsen):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Submission to correct this defect produced revision 5270.
 While the GeometryApiGen.xml file was correctly updated, the RFC 94
 submission
 did not correctly update the MapGuideApiGen.xml file thus the generation
 of the
 Java version of the API failed.  Thee associated ..Constant.xml files were
 similarly handled.
 Neither were the Makefile.am files for Java and Php updated to include the
 new
 interfaces.  Correcting that issue lead to the discovery that the
 implementation of RFC 76  (Grids and MGRS) did not include several new
 classes
 in the Makefile.am files.  This situation was corrected as well.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1456#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
