[mapguide-trac] #1281: Path corrections and small template extensions in mapviewerphp/layerdefinitionfactory.php
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 9 18:31:23 EST 2010
   Reporter:  gabrimonfa   |       Owner:  brucedechant
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  2.3
  Component:  General      |     Version:  2.1.0
   Severity:  trivial      |    Keywords:
External_id:               |
Description changed by brucedechant:
Old description:
> All path in mapviewerphp/layerdefinitionfactory.php pointing to
> ../../viewerfiles should be corrected to ../viewerfiles
> CreateAreaRule can be extended to accept two more parameters,
> $strokeThickness and $strokeColor.
> CreateLineRule can be extended to accept one more parameter,
> $strokeThickness
> This two last modifications require to modify accordingly also the
> areaRule e lineRule templates in viewerfiles.
> All attached unified diff files refer to <file>_20100226.php (the
> original one) and <file>.php (the modified one)
New description:
 !CreateAreaRule can be extended to accept two more parameters,
 !CreateLineRule can be extended to accept one more parameter,
 $strokeThickness
 areaRule and lineRule templates in viewerfiles.
 All attached unified diff files refer to <file>_20100226.php (the original
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1281#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
