[mapguide-trac] #1524: GETMAPLEGENDIMAGE should allow for scalable text and icons
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 15 00:55:52 EST 2010
   Reporter:  jng                |       Owner:
       Type:  defect             |      Status:  new
   Priority:  medium             |   Milestone:
  Component:  Rendering Service  |     Version:
   Severity:  major              |    Keywords:
External_id:                     |
 Regardless of how big the size of the image you request in the
 GETMAPLEGENDIMAGE the size of the text and icons are always drawn at the
 same size.
 If you are doing A3 or bigger sized custom plotting using this call, the
 image output of this call will start to become unreadable as the text and
 icons will always be the same size and the operation in its current form
 has no way to specify custom scales for the rendered text and icons.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1524>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
