[mapguide-trac] #1476: mgserver lock up using GDAL Plugins (mrsid)
MapGuide Open Source trac_mapguide at osgeo.org
Sun Nov 21 11:30:19 EST 2010
   Reporter:  andrewd   |       Owner:  trevorwekel
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:
  Component:  Server    |     Version:  2.2.0
   Severity:  critical  |    Keywords:
External_id:            |
Changes (by trevorwekel):
  * owner:  => trevorwekel
Comment:
 Hi Andrew, I have a testing environment set up on a 64 bit OS and I am
 having zero luck getting the MrSID plug in to work.  The MapGuide Server
 freezes when the SID is accessed and throws an invalid heap error.  I
 suspect it might be WOW64 conflict with the msvcr71.dll (circa Visual
 Studio .Net 2003) which is needed by the plugin.
 However, I can access the SID on a 32 bit OS.  Did you install MapGuide 32
 bit on 64 bit OS?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1476#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
