[mapguide-trac] #1531: Managed SHP no longer adds similar files automatically
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 22 12:44:33 EST 2010
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:  2.1.0
   Severity:  minor    |    Keywords:
External_id:           |
 Maestro v3.0.0.5334 seem to have lost a very useful function when working
 with SHP feature sources (and likely all feature sources).
 In previous versions, when you added some managed data, Maestro would look
 for similarly named files (ie, same name - different extension) and then
 ask the user if they'd like to add the additional files. This no longer
 happens in v3, which makes SHP feature sources rather annoying to create,
 since you always need to add more than 1 file (dbf, shp, shx, maybe a prj,
 etc).
 If this is no longer possible in v3, then the user should at least be
 allowed to select more than 1 file at a time. In a perfect world, one
 could select a few different .shp files at once ''and'' have Maestro
 automatically bring in the rest.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1531>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
