[mapguide-trac] #1538: Speed up Coordinate System Dictionary lookup when reading all CS definitions at one
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 25 15:44:28 EST 2010
definitions at one
   Reporter:  baertelchen  |       Owner:  baertelchen
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  2.3
  Component:  General      |     Version:  2.1.0
   Severity:  minor        |    Keywords:  Coordinate System API
External_id:               |
 When reading all available coordinate system definitions from the
 dictionary (in this case, from coordsys.csd), the current implementation
 does (way too) many file look ups via CsMap. For each(!) CS definition to
 be read (out of thousands), the implementation will first read the CS'
 name (1), this name is later taken to read the CS' definition (2). When
 creating the MgCoordinateSystem instance, the CS' datum is taken and the
 MgCsDatum instance is created(3). While creating the MgCsDatum instance,
 the MgEllipsoid instance is also created (4).
 The numbers indicate the file accesses via CsMap. This includes a global
 in-process lock, the file access itself inside CsMap (which does a divide-
 and-conquer-like search within the file) and the construction of the
 object.
 This ticket is to fix the implementation of
 [MgCoordinateSystemEnum::Next(UINT32 ulCount)] in
 [CoordSysEnum::Next(UINT32 ulCount)] as returned by the
 [CoordSysDictionary] class.
 That is, when an API client is about to read ALL available systems (as
 indicated by the UINT32 ulCount parameter), the lookup has to be much
 faster.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1538>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
