[mapguide-trac] #1542: Implementation of CCoordinateSystemGeodeticPath::IsValid() is incorrect
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 29 16:00:20 EST 2010
 Reporter:  NormOlsen               |         Owner:  NormOlsen
     Type:  defect                  |        Status:  closed
 Priority:  medium                  |     Milestone:  2.3
Component:  General                 |       Version:  2.1.0
 Severity:  minor                   |    Resolution:  fixed
 Keywords:  CoordinateSystems Path  |   External_id:  1354323
Changes (by NormOlsen):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Code to check the components of a Path definition were removed from the
 CoordinateSystem interfave and replaced with a call to the newly
 implemented CS_gpchk() function which perfromed same, and more.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1542#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
