[mapguide-trac] #1545: Safari 5: Session Expired message pop-up several times when Zoom in on map
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 30 21:42:31 EST 2010
   Reporter:  ChristineBao  |       Owner:  Christine Bao
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  2.2
  Component:  General       |     Version:  2.1.0
   Severity:  major         |    Keywords:
External_id:  1344146       |
 Report from Autodesk QA:[[BR]]
 Steps:[[BR]]
 1. Open one basic web layout by Safari 5 which "keep connection alive" is
 unchecked.[[BR]]
 2. Leave it aside for more than 20 mins ( or, you could set the session
 timeout as one small value maybe 30 seconds)[[BR]]
 3. zoom in after session time-out
 Results:[[BR]]
 One warning message pop-up. Click ok, the message popped up again.
 This message was popped up several times. Finally user have no choice but
 to kill Safari.
 Expected results:[[BR]]
 After click ok on the first warning message, it shouldn't pop-up again.
 [[BR]]
 IE8 works correctly.
 Workaround: N[[BR]]
 Regression: N
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1545>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
