[mapguide-trac] #1461: Crash when server repository busy
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 12 15:29:10 EDT 2010
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:  2.2.0
   Severity:  trivial  |    Keywords:
External_id:           |
 When restoring a large package (via the admin site, not Maestro), if I try
 to log in to the server using Maestro, I get a crash - the details seem to
 indicate that what should happen is a message explaining that the server
 is busy, and to try again later. I did eventually get in, once the package
 was restored. Here's the info:
 See the end of this message for details on invoking
 just-in-time (JIT) debugging instead of this dialog box.
 ************** Exception Text **************
 System.Exception: The remote server returned an error: (559)
 MgDbXmlException.:
 An exception occurred in DB XML component.
 Please try your operation later as the repository was busy.
  ---> System.Net.WebException: The remote server returned an error: (559)
 MgDbXmlException.
    at System.Net.WebClient.OpenRead(Uri address)
    at System.Net.WebClient.OpenRead(String address)
    at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req)
    --- End of inner exception stack trace ---
    at
 OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetRepositoryResources(String
 startingpoint, String type, Int32 depth, Boolean computeChildren)
    at
 OSGeo.MapGuide.Maestro.ResourceBrowser.RepositoryCache.ResourceFolder.ReloadContents()
    at
 OSGeo.MapGuide.Maestro.ResourceBrowser.RepositoryCache.BuildNode(TreeNode
 node, Boolean forceRebuild)
    at
 OSGeo.MapGuide.Maestro.ResourceBrowser.ResourceTree.ResourceTree_BeforeExpand(Object
 sender, TreeViewCancelEventArgs e)
    at System.Windows.Forms.TreeView.OnBeforeExpand(TreeViewCancelEventArgs
 e)
    at System.Windows.Forms.TreeView.TvnExpanding(NMTREEVIEW* nmtv)
    at System.Windows.Forms.TreeView.WmNotify(Message& m)
    at System.Windows.Forms.TreeView.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
 m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
 IntPtr wparam, IntPtr lparam)
 ************** Loaded Assemblies **************
 mscorlib
     Assembly Version: 2.0.0.0
     Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
     CodeBase:
 file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
 Maestro
     Assembly Version: 2.1.4.5245
     Win32 Version: 2.1.4.5245
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/Maestro.exe
 OSGeo.MapGuide.Maestro.LoginForm
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.LoginForm.DLL
     Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
 System
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
 System.Drawing
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
 System.Xml
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
 System.Configuration
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
 iwbok5kv
     CodeBase:
 OSGeo.MapGuide.Maestro.MaestroEditorInterface
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.MaestroEditorInterface.DLL
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.MaestroAPI.DLL
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.ResourceBrowser.DLL
 OSGeo.MapGuide.Maestro.ResourceValidators
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.ResourceValidators.DLL
 System.Data
     CodeBase:
 file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
 System.Web
     Win32 Version: 2.0.50727.4955 (win7RTMGDR.050727-4900)
     CodeBase:
 file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
 Microsoft.JScript
     Assembly Version: 8.0.0.0
     Win32 Version: 8.0.50727.4927
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll
 5fowlk-a
     CodeBase:
 zgy7lbka
     CodeBase:
 OSGeo.MapGuide.Maestro.ResourceEditors
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.ResourceEditors.DLL
 OSGeo.MapGuide.Maestro.FusionEditor
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.FusionEditor.DLL
 ************** JIT Debugging **************
 To enable just-in-time (JIT) debugging, the .config file for this
 application or computer (machine.config) must have the
 jitDebugging value set in the system.windows.forms section.
 The application must also be compiled with debugging
 enabled.
 For example:
 <configuration>
     <system.windows.forms jitDebugging="true" />
 </configuration>
 When JIT debugging is enabled, any unhandled exception
 will be sent to the JIT debugger registered on the computer
 rather than be handled by this dialog box.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1461>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
