[mapguide-trac] #1465: Maestro crash when restorign large packageo (MGOS 2.2 RC1)
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 13 10:05:34 EDT 2010
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:
External_id:           |
 I keep getting the following crash when I restore a large package. This is
 using MGOS 2.2 RC1 (happens with both x64 and x86). The package restores
 fine - the crash just happens while waiting to hear from the server.
 Rather trivial - but a crash that's consistent..
 See the end of this message for details on invoking
 just-in-time (JIT) debugging instead of this dialog box.
 ************** Exception Text **************
 System.Net.WebException: The underlying connection was closed: The
 connection was closed unexpectedly.
    at
 OSGeo.MapGuide.MaestroAPI.PackageBuilder.PackageProgress.backgroundWorker_RunWorkerCompleted(Object
 sender, RunWorkerCompletedEventArgs e)
    at
 System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs
 e)
    at
 System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg)
 ************** Loaded Assemblies **************
 mscorlib
     Assembly Version: 2.0.0.0
     Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
     CodeBase:
 file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
 Maestro
     Assembly Version: 2.1.4.5245
     Win32 Version: 2.1.4.5245
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/Maestro.exe
 OSGeo.MapGuide.Maestro.LoginForm
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.LoginForm.DLL
 System.Windows.Forms
     Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
 System
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
 System.Drawing
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
 System.Xml
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
 System.Configuration
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
 onjcijhf
     CodeBase:
 OSGeo.MapGuide.Maestro.MaestroEditorInterface
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.MaestroEditorInterface.DLL
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.MaestroAPI.DLL
 OSGeo.MapGuide.Maestro.ResourceBrowser
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.ResourceBrowser.DLL
 OSGeo.MapGuide.Maestro.ResourceValidators
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.ResourceValidators.DLL
 System.Data
     CodeBase:
 file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
 System.Web
     Win32 Version: 2.0.50727.4955 (win7RTMGDR.050727-4900)
     CodeBase:
 file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
 Microsoft.JScript
     Assembly Version: 8.0.0.0
     Win32 Version: 8.0.50727.4927
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll
 pnzwpowq
     CodeBase:
 i-vb-uhe
     CodeBase:
 OSGeo.MapGuide.Maestro.ResourceEditors
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.ResourceEditors.DLL
 OSGeo.MapGuide.Maestro.FusionEditor
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.FusionEditor.DLL
 zmkobt_p
     CodeBase:
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.MaestroAPI.PackageBuilder.DLL
 2dv4z5tl
     CodeBase:
 ************** JIT Debugging **************
 To enable just-in-time (JIT) debugging, the .config file for this
 application or computer (machine.config) must have the
 jitDebugging value set in the system.windows.forms section.
 The application must also be compiled with debugging
 enabled.
 For example:
 <configuration>
     <system.windows.forms jitDebugging="true" />
 </configuration>
 When JIT debugging is enabled, any unhandled exception
 will be sent to the JIT debugger registered on the computer
 rather than be handled by this dialog box.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1465>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
