[mapguide-trac] #1471: Mapguide Maestro 2.1. Validating a layer based on a view does not always work
MapGuide Open Source trac_mapguide at osgeo.org
Fri Oct 15 13:06:34 EDT 2010
work
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:  2.1.0
   Severity:  trivial     |    Keywords:
External_id:              |
 Mapguide Maestro 2.1.4
 Some views are reported as missing in the feature source even if they are
 found and correctly used by Mapguide 2.1 & 2.2.
 I'm using OGR Provider and PostgreSQL 8.3 (gdal recompiled to connect to
 PostgreSQL/PostGIS).
 Some other instead are reported as correct.
 Apparently it doesn't matter if a field in the view is of type integer and
 has unique values
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1471>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
