[mapguide-trac] #1472: Mapguide Maestro 2.1. Validating a layer with scale ranges not in the correct order reports them as overlapping
MapGuide Open Source trac_mapguide at osgeo.org
Fri Oct 15 13:09:21 EDT 2010
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:  2.1.0
   Severity:  trivial     |    Keywords:
External_id:              |
 When the first scale range is not the smaller, the ranges are reported as
 overlapping even if they are not.
 Tipical example, 2 scale ranges, the first from 10000 to Infinity, the
 second from 0 to 9999.
 Manually modifying the xml to invert their order makes the layer pass the
 validation
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1472>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
