[mapguide-trac] #1475: Maestro 2.1.4 Setting false in "Group is shown in the map legend" in maps does not work
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 19 07:00:24 EDT 2010
does not work
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:  2.1.0
   Severity:  trivial     |    Keywords:
External_id:              |
 Step to reproduce the issue
 1. Open a map with groups
 2. Select one group and set "Group is shown in the map legend" as false
 3. save the map
 4. select again the same group
 The option "Group is shown in the map legend" is checked, while it should
 not.
 Closing and reopening the map shows that it has been indeed saved
 incorrectly.
 Opening the map as xml it is possible to save the group as invisible in
 the legend.
 Moreover, calling the xml editor from the main toolbar while the map is
 open in normal view, setting false to the property and closing the xml
 editor removes the check and the map is then saved correctly.
 Does removing the check in the normal view forgets to do the proper xml
 modifications?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1475>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
