[mapguide-trac] #1477: ODBC dataconnection (MS Access) problem
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 20 08:34:27 EDT 2010
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Comment(by andrewd):
 Maestro config doc:
 <?xml version="1.0" encoding="utf-8"?>
 <fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
 xmlns:xlink="http://www.w3.org/1999/xlink"
 xmlns:gml="http://www.opengis.net/gml"
 xmlns:fdo="http://fdo.osgeo.org/schemas"
 xmlns:fds="http://fdo.osgeo.org/schemas/fds">
   <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
 targetNamespace="http://fdo.osgeo.org/schemas/feature/Default"
 xmlns:Fdo="http://fdo.osgeo.org/schemas/feature/Fdo"
 elementFormDefault="qualified" attributeFormDefault="unqualified"
 xmlns:Default="http://fdo.osgeo.org/schemas/feature/Default">
     <xs:element name="Dig_Sheet" type="Default:Dig_SheetType"
 abstract="false" substitutionGroup="gml:_Feature">
       <xs:key name="Dig_SheetKey">
         <xs:selector xpath=".//Dig_Sheet" />
         <xs:field xpath="Item_ID" />
       </xs:key>
     </xs:element>
     <xs:complexType name="Dig_SheetType" abstract="false"
 hasGeometry="false">
       <xs:complexContent>
         <xs:extension base="fdo:ClassType">
           <xs:sequence>
             <xs:element name="Item_ID" minOccurs="0">
               <xs:simpleType>
                 <xs:restriction base="xs:string">
                   <xs:maxLength value="50" />
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Anom_Type" minOccurs="0">
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
             <xs:element name="MEC_Typ" minOccurs="0">
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
             <xs:element name="MPPEH_Typ" minOccurs="0">
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Rc_Itm_Cnt" minOccurs="0">
               <xs:simpleType>
                 <xs:restriction base="xs:float" />
               </xs:simpleType>
             </xs:element>
             <xs:element name="Descript" minOccurs="0">
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Nomenclat" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Depth" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Angle" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Itm_Length" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Itm_Width" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Weight" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Weight_Tot" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Date" minOccurs="0">
               <xs:simpleType>
                 <xs:restriction base="xs:dateTime" />
               </xs:simpleType>
             </xs:element>
             <xs:element name="Fin_Dispos" minOccurs="0">
               <xs:simpleType>
                   <xs:maxLength value="255" />
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Fin_DisDat" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Post_X_Res" minOccurs="0">
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Photo_Name" minOccurs="0">
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Comment" minOccurs="0">
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
           </xs:sequence>
         </xs:extension>
       </xs:complexContent>
     </xs:complexType>
     <xs:element name="Targets" type="Default:TargetsType" abstract="false"
       <xs:key name="TargetsKey">
         <xs:selector xpath=".//Targets" />
         <xs:field xpath="Target_ID" />
       </xs:key>
     </xs:element>
     <xs:complexType name="TargetsType" abstract="false" hasGeometry="true"
 geometryName="Geometry">
       <xs:complexContent>
         <xs:extension base="gml:AbstractFeatureType">
           <xs:sequence>
             <xs:element name="Target_ID" minOccurs="0">
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Northing" minOccurs="0">
               <xs:simpleType>
                 <xs:restriction base="xs:double" />
               </xs:simpleType>
             </xs:element>
             <xs:element name="Easting" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Channel1" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Channel3" minOccurs="0">
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
             <xs:element name="Geometry" type="gml:AbstractGeometryType"
 hasMeasure="false" hasElevation="false" geometricTypes="point"
 geometryTypes="point multipoint" />
           </xs:sequence>
         </xs:extension>
     </xs:complexType>
     <xs:complexType name="All_DataType" abstract="false"
       <xs:complexContent>
           <xs:sequence>
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
               <xs:simpleType>
                 </xs:restriction>
               </xs:simpleType>
             </xs:element>
           </xs:sequence>
         </xs:extension>
     </xs:complexType>
     <xs:element name="All_Data" type="Default:All_DataType"
       <xs:key name="All_DataKey">
         <xs:selector xpath=".//All_Data" />
       </xs:key>
     </xs:element>
   </xs:schema>
   <SchemaMapping xmlns:rdb="http://fdordbms.osgeo.org/schemas"
 xmlns="http://fdoodbc.osgeo.org/schemas" provider="OSGeo.ODBC.3.3"
 name="Default">
     <complexType name="Dig_SheetType">
       <Table name="Dig_Sheet" />
       <element name="Item_ID">
         <Column name="Item_ID" />
       </element>
       <element name="Anom_Type">
         <Column name="Anom_Type" />
       </element>
       <element name="MEC_Typ">
         <Column name="MEC_Typ" />
       </element>
       <element name="MPPEH_Typ">
         <Column name="MPPEH_Typ" />
       </element>
       <element name="Rc_Itm_Cnt">
         <Column name="Rc_Itm_Cnt" />
       </element>
       <element name="Descript">
         <Column name="Descript" />
       </element>
       <element name="Nomenclat">
         <Column name="Nomenclat" />
       </element>
       <element name="Depth">
         <Column name="Depth" />
       </element>
       <element name="Angle">
         <Column name="Angle" />
       </element>
       <element name="Itm_Length">
         <Column name="Itm_Length" />
       </element>
       <element name="Itm_Width">
         <Column name="Itm_Width" />
       </element>
       <element name="Weight">
         <Column name="Weight" />
       </element>
       <element name="Weight_Tot">
         <Column name="Weight_Tot" />
       </element>
       <element name="Date">
         <Column name="Date" />
       </element>
       <element name="Fin_Dispos">
         <Column name="Fin_Dispos" />
       </element>
       <element name="Fin_DisDat">
         <Column name="Fin_DisDat" />
       </element>
       <element name="Post_X_Res">
         <Column name="Post_X_Res" />
       </element>
       <element name="Photo_Name">
         <Column name="Photo_Name" />
       </element>
       <element name="Comment">
         <Column name="Comment" />
       </element>
     </complexType>
     <complexType name="TargetsType">
       <Table name="Targets" />
       <element name="Target_ID">
         <Column name="Target_ID" />
       </element>
       <element name="Northing">
         <Column name="Northing" />
       </element>
       <element name="Easting">
         <Column name="Easting" />
       </element>
       <element name="Channel1">
         <Column name="Channel1" />
       </element>
       <element name="Channel3">
         <Column name="Channel3" />
       </element>
       </element>
       <element name="Geometry" xColumnName="Easting"
 yColumnName="Northing" />
     </complexType>
     <complexType name="All_DataType">
       <Table name="All_Data" />
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
       </element>
     </complexType>
   </SchemaMapping>
 </fdo:DataStore>
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1477#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
