[mapguide-trac] #1481: getselectedfeatures should use more efficient centroid processing
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 20 23:07:10 EDT 2010
   Reporter:  jng          |       Owner:  jng
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:  2.2
  Component:  AJAX Viewer  |     Version:  2.2.0
   Severity:  major        |    Keywords:
External_id:               |
 The current getselectedfeatures.aspx/php/jsp uses MgGeometry.GetCentroid()
 to calculate the zoom location.
 It turns out GetCentroid() does a full scan of the geometry's WKT.
 For geometries with an absurd amount of vertices, this is a woefully
 inefficient method of calculating the centroid.
 Since the purpose of this centroid is to be the zoom location, we don't
 exactly require a *precise* zoom location. Something approximate should
 suffice. So the centroid processing should change from this:
 MgCoordinate pt = geom.Centroid.Coordinate
 zoom.X = pt.X;
 zoom.Y = pt.Y;
 to this:
 MgEnvelope env = geom.Envelope();
 MgCoordinate ll = env.GetLowerLeftCoordinate();
 MgCoordinate ur = env.GetUpperRightCoordinate();
 zoom.X = (ur.X + ll.X) / 2;
 zoom.Y = (ur.Y + ll.Y) / 2;
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1481>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
