[mapguide-trac] #1483: Maestro: selecting a new category in the New Resource dialog doesn't deselect the current template
MapGuide Open Source trac_mapguide at osgeo.org
Thu Oct 21 07:03:05 EDT 2010
   Reporter:  jbirch   |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 With the 3.0 preview, selecting a template changes the description and
 enables the Add button.  When you change categories, a template is no
 longer selected, but the description remains set to the previously
 selected template and the Add button remains active.  Clicking on the Add
 button causes an exception.
 I would suggest clearing the description and disabling the Add button when
 switching categories.
 As an aside, the dialog is called "New Resource", but the context menu
 item is "New Item"
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1483>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
