[mapguide-trac] #1486: Modify getselectedfeatures to return an envelope for each feature instead of a point
MapGuide Open Source trac_mapguide at osgeo.org
Thu Oct 21 11:13:48 EDT 2010
of a point
   Reporter:  jng          |       Owner:
       Type:  defect       |      Status:  new
   Priority:  high         |   Milestone:  2.3
  Component:  AJAX Viewer  |     Version:  2.2.0
   Severity:  trivial      |    Keywords:
External_id:               |
 The getselectedfeatures script should change its JSON response to return
 an envelope instead of a point.
 By returning an envelope we can harness the existing zoom to selection
 code already in the viewer, and thus instead of zooming to the centroid of
 a particular feature at a pre-defined zoom level (which may not be
 appropriate) it will always zoom to the full extents of that feature,
 which is our desired result
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1486>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
