[mapguide-trac] #1439: Load Proceedure coord system
MapGuide Open Source trac_mapguide at osgeo.org
Thu Oct 21 23:08:53 EDT 2010
   Reporter:  andrewd      |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  medium       |   Milestone:  Maestro-3.0
  Component:  Maestro      |     Version:  2.1.0
   Severity:  minor        |    Keywords:
External_id:               |
Comment(by jng):
 Is this in the actual Load Procedure schema? Because the CoordinateSystem
 schema element defines the coordinate system to assign if none is found.
 There is no boolean option in the schema to say override with the
 specified CoordinateSystem, meaning this option (if I implemented it)
 cannot be saved.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1439#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
