[mapguide-trac] #1493: Resize window caused dynamic layers disappear if the map with Base layers in Chrome/Safari
MapGuide Open Source trac_mapguide at osgeo.org
Fri Oct 22 05:28:19 EDT 2010
in Chrome/Safari
   Reporter:  yangte       |       Owner:  yangte
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:  2.3
  Component:  AJAX Viewer  |     Version:  2.2.0
   Severity:  major        |    Keywords:  resize
External_id:  1356304      |
Comment(by yangte):
 When the map has base layer group, the ajaxviewer will hide the dynamic
 map image div first.
 function HideMapImage()
     if(!HasVisibleBaseGroups())
         return;
     document.getElementById("img1").style.display = "none";
 In the code for IE/Firefox, the Ajax viewer will unhide the map image div:
 function OnMapOverlayImageLoaded(e)
 var imgdiv = document.getElementById("img1");
         img.src = overlayimg.src;
         img.style.position = "absolute";
         img.style.visibility = "visible";
         img.style.width = mapDevW;
         img.style.height = mapDevH;
         img.style.left = 0;
         img.style.top = 0;
     imgdiv.style.display = "block";
 However, in the code for !Chrome/Safari, someone forgot to unhide the map
 image div:
 function OnAlternateImageLoaded()
     // Show the newly loaded image
     img.style.left = 0;
     img.style.top = 0;
 so the solution is to simply unhide the div.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1493#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
